Billboards visible while on the other side of the globe
Hello everyone,
Billboards are visible while on the other side of the planet
Here is a sandcastle exemple of this behaviour (bug ?) : sandcastle
A video is also available here : video
It seems to occur while I have these parameters set up for the viewer :
viewer.scene.globe.depthTestAgainstTerrain = true;
viewer.scene.globe.backFaceCulling = false;
viewer.scene.globe.showSkirts = false;
viewer.scene.screenSpaceCameraController.enableCollisionDetection = false;
Billboards themselves have :
disableDepthTestDistance : Number.POSITIVE_INFINITY,
heightReference : Cesium.HeightReference.CLAMP_TO_GROUND
I need my billboards to not be cropped by terrain at high altitude, while at the same time 3DTilesets mustn’t be visible while underground if the camera is above ground.
As some of these 3DTileset are under the terrain (subway 3d data), I need to be able to see what’s underground, and so disabling skirts, backFaceCulling, camera collision and so on.
This behaviour is present using cesiumJS 1.66 and 1.67, on windows, google chrome latest version.
I don’t know if it is still there in 1.68, with the “automatic” underground setting (https://github.com/CesiumGS/cesium/pull/8572)
Setting disableDepthTestDistance to infinity makes these billboards always show through. Ideally what you want is to be able to set disableDepthTestAgainstTerrain to false but only for the billboards, which isn’t currently supported. I opened a feature request for this here: https://github.com/CesiumGS/cesium/issues/8685
