When zooming in and out with billboard clusters, the levels at which billboards cluster and uncluster is inconsistent. It seems that pixelRange is applied to determine when to group billboards into a cluster, but the cluster is “sticky” when zooming in and does not break apart until some zoom level where a significantly larger pixel range is seen.
This can be reproduced with the clustering demo. Here are steps:
Set “Pixel Range” to 100 and “Minimum Cluster Size” to 2.
Zoom in to get to a place where 2 billboards are nearby and may be clustered
Slowly zoom out from the 2 billboards and notice the last zoom level before the billboards combine. For example:
- Slowly zoom in and notice that you need to keep zooming past the level from above to get the billboards to uncluster. For example, the billboards are located on the white circles in the image below, which is much greater pixel separation than the image above. As a result, I expect that the billboards should already be unclustered.
This looks like a general issue with the clustering feature, as the inconsistency detracts from the experience of using clustering. Ideally, the clustering results for a zoom level would be consistent and reproducible.
