Hi Toby,
You would need to create a custom animation and its quite a bit of code, sorry. Here’s some code that would work in 3D only:
// create a quaternion from basis
function createQuaternion(direction, up) {
var right = Cartesian3.cross(direction, up);
var orthoUp = Cartesian3.cross(right, direction);
viewMat[0] = right.x;
viewMat[1] = orthoUp.x;
viewMat[2] = -direction.x;
viewMat[3] = right.y;
viewMat[4] = orthoUp.y;
viewMat[5] = -direction.y;
viewMat[6] = right.z;
viewMat[7] = orthoUp.z;
viewMat[8] = -direction.z;
return Quaternion.fromRotationMatrix(viewMat);
// save start and end camera position and orientation
// endPosition, endDirection, and endUp are assumed to exist
var startPosition = Cartesian3.clone(camera.position);
var startOrientation = createQuaternion(camera.direction, camera.up);
var endOrientation = createQuaternion(endDirection, endUp);
// animation update function
// time assumed to be in [0.0, 1.0]
var update = function(value) {
var time = value.time;
var orientation = Quaternion.slerp(startOrientation, endOrientation, time);
var rotMatrix = Matrix3.fromQuaternion(orientation);
Cartesian3.lerp(startPosition, endPosition, time, camera.position);
Matrix3.getRow(rotMatrix, 0, camera.right);
Matrix3.getRow(rotMatrix, 1, camera.up);
Matrix3.getRow(rotMatrix, 2, camera.direction);
Cartesian3.negate(camera.direction, camera.direction);
var animation = {
duration : duration,
easingFunction : Tween.Easing.Sinusoidal.InOut,
startValue : {
time : 0.0
stopValue : {
time : 1.0
onUpdate : update
animation is an object like that returned from the CameraFlightPath.createAnimation* functions.
Dan
