Cant Connect to Cesium for Unreal
Invalid redirect. Please contact the developer of the “Cesium for Unreal” application to check the configuration. Message shows Up
same here. any luck?
same
same
Also same error, tried in different browsers
Facing the same problem. How do we contact the developer?
Same, I can’t connect (it worked perfectly yesterday).
The issue is currently being investigated. Updates will be posted in this thread as soon as possible.
The reason for the error has been identified, and a fix is underway. An update will be posted here when the fix is deployed.
The issue should be resolved now. Please drop a note here if you are still encountering problems.
I still cannot get in.
Hi @Kanousei, welcome to the community!
It’s possible you’re experiencing a different problem. Please share as much detail as you can about the problem you’re seeing, so that we can help solve it.
