I have followed the instructions in:
https://github.com/AnalyticalGraphicsInc/cesium/tree/master/Documentation/Contributors/BuildGuide
Specifically:
git clone git@github.com:AnalyticalGraphicsInc/cesium.git
npm install
npm run build
npm start
The server starts but naturally cesium.js is not found in that folder
Latest fom Git Hub 2017/10/25
Windows to
node 6.11.1
The Build instructions (https://github.com/AnalyticalGraphicsInc/cesium/tree/master/Documentation/Contributors/BuildGuide)
Suggest 6.x or higher. I am using 6.11.1.
What node version should I be using?
Hi Garth,
Node 6+ should be fine.
Did everything install correctly on npm install? Also you’re running the npm commands at the root Cesium directory, correct?
Can you provide an error messages or logs? I’m at a loss for what exactly is going wrong here.
Gabby
Thanks for the logs.
It looks like your missing a file:
[09:15:11] Error: ENOENT: no such file or directory, open ‘Apps/.jshintrc’
I downloaded and unzipped the latest release and I’m running into the same error. Thanks for bringing this to our attention, we’ll get this fixed ASAP. In the meantime, you can run npm start without building if you haven’t modified cesium at all. If you do need to modify Cesium code, try cloning the repo from GitHub.
Thanks!
Gabby
