I try to npm run-script build command Command completed in short time and Build folder cannot be created. So I cannot see anything, Sandcastle, HelloWord.html etc.
I checked out master and ı did’nt any change on it.
Can you help me about it. I think Travis CI cannot build my branch that I open for contribute an issue.
