Hi everyone,
We’re starting the 1.20 release. It will be out later today.
Dan
Hi everyone,
Dan
Cesium 1.20 is now available: http://cesiumjs.org/downloads.html
Dan
Hi, guys!
I’m unable to build 1.20. 'minifyRelease` now prepares only some images for widgets and textures. Is anything changed there? Below is how I do it:
ezze@ezze-laptop:~/Development/cesium-bower/cesium$ git checkout 1.20
Note: checking out ‘1.20’.
You are in ‘detached HEAD’ state. You can look around, make experimental
changes and commit them, and you can discard any commits you make in this
state without impacting any branches by performing another checkout.
If you want to create a new branch to retain commits you create, you may
do so (now or later) by using -b with the checkout command again. Example:
git checkout -b new_branch_name
HEAD is now at e49fb89… Merge pull request #3798 from AnalyticalGraphicsInc/fix-ie-failures
ezze@ezze-laptop:~/Development/cesium-bower/cesium$ npm run clean
cesium@1.20.0 clean /home/ezze/Development/cesium-bower/cesium
gulp clean
[11:27:12] Using gulpfile ~/Development/cesium-bower/cesium/gulpfile.js
[11:27:12] Starting ‘clean’…
[11:27:12] Finished ‘clean’ after 82 ms
ezze@ezze-laptop:~/Development/cesium-bower/cesium$ npm run minifyRelease
cesium@1.20.0 minifyRelease /home/ezze/Development/cesium-bower/cesium
gulp minifyRelease
[11:27:18] Using gulpfile ~/Development/cesium-bower/cesium/gulpfile.js
[11:27:18] Starting ‘build’…
[11:27:19] Finished ‘build’ after 649 ms
[11:27:19] Starting ‘generateStubs’…
[11:27:19] Finished ‘generateStubs’ after 142 ms
[11:27:19] Starting ‘minifyRelease’…
Building Cesium.js
Building Source/Workers/cesiumWorkerBootstrapper.js
Building Source/Workers/transferTypedArrayTest.js
Building Source/ThirdParty/Workers/deflate.js
Building Source/ThirdParty/Workers/inflate.js
Finished Source/ThirdParty/Workers/deflate.js
Finished Source/Workers/transferTypedArrayTest.js
Finished Cesium.js
Finished Source/ThirdParty/Workers/inflate.js
Finished Source/Workers/cesiumWorkerBootstrapper.js
Building Source/Workers/combineGeometry.js
Building Source/Workers/createBoxGeometry.js
Building Source/Workers/createBoxOutlineGeometry.js
Building Source/Workers/createCircleGeometry.js
Finished Source/Workers/combineGeometry.js
Building Source/Workers/upsampleQuantizedTerrainMesh.js
Finished Source/Workers/createBoxGeometry.js
Building Source/Workers/createWallOutlineGeometry.js
Finished Source/Workers/createBoxOutlineGeometry.js
Building Source/Workers/createWallGeometry.js
Finished Source/Workers/createCircleGeometry.js
Building Source/Workers/createVerticesFromQuantizedTerrainMesh.js
Finished Source/Workers/upsampleQuantizedTerrainMesh.js
Building Source/Workers/createVerticesFromHeightmap.js
Finished Source/Workers/createWallGeometry.js
Building Source/Workers/createSphereOutlineGeometry.js
Finished Source/Workers/createWallOutlineGeometry.js
Building Source/Workers/createSphereGeometry.js
Finished Source/Workers/createVerticesFromQuantizedTerrainMesh.js
Building Source/Workers/createSimplePolylineGeometry.js
Finished Source/Workers/createVerticesFromHeightmap.js
Building Source/Workers/createRectangleOutlineGeometry.js
Finished Source/Workers/createSphereOutlineGeometry.js
Building Source/Workers/createRectangleGeometry.js
Finished Source/Workers/createSphereGeometry.js
Building Source/Workers/createPolylineVolumeOutlineGeometry.js
Finished Source/Workers/createSimplePolylineGeometry.js
Building Source/Workers/createPolylineVolumeGeometry.js
Finished Source/Workers/createRectangleOutlineGeometry.js
Building Source/Workers/createPolylineGeometry.js
Finished Source/Workers/createPolylineVolumeOutlineGeometry.js
Building Source/Workers/createPolygonOutlineGeometry.js
Finished Source/Workers/createRectangleGeometry.js
Building Source/Workers/createPolygonGeometry.js
Finished Source/Workers/createPolylineVolumeGeometry.js
Building Source/Workers/createPointGeometry.js
Finished Source/Workers/createPolylineGeometry.js
Building Source/Workers/createGeometry.js
Finished Source/Workers/createPolygonGeometry.js
Building Source/Workers/createEllipsoidOutlineGeometry.js
Finished Source/Workers/createPointGeometry.js
Building Source/Workers/createEllipsoidGeometry.js
Finished Source/Workers/createPolygonOutlineGeometry.js
Building Source/Workers/createEllipseOutlineGeometry.js
Finished Source/Workers/createGeometry.js
Building Source/Workers/createEllipseGeometry.js
Finished Source/Workers/createEllipsoidOutlineGeometry.js
Building Source/Workers/createCylinderOutlineGeometry.js
Finished Source/Workers/createEllipsoidGeometry.js
Building Source/Workers/createCylinderGeometry.js
Finished Source/Workers/createEllipseOutlineGeometry.js
Building Source/Workers/createCorridorOutlineGeometry.js
Finished Source/Workers/createEllipseGeometry.js
Building Source/Workers/createCorridorGeometry.js
Finished Source/Workers/createCylinderOutlineGeometry.js
Building Source/Workers/createCircleOutlineGeometry.js
Finished Source/Workers/createCylinderGeometry.js
Finished Source/Workers/createCorridorOutlineGeometry.js
Finished Source/Workers/createCorridorGeometry.js
Finished Source/Workers/createCircleOutlineGeometry.js
Building Source/Widgets/Animation/Animation.css
Building Source/Widgets/Animation/lighter.css
Building Source/Widgets/BaseLayerPicker/BaseLayerPicker.css
Building Source/Widgets/BaseLayerPicker/lighter.css
Finished Source/Widgets/Animation/Animation.css
Building Source/Widgets/widgets.css
Finished Source/Widgets/Animation/lighter.css
Building Source/Widgets/shared.css
Finished Source/Widgets/BaseLayerPicker/BaseLayerPicker.css
Building Source/Widgets/lighterShared.css
Finished Source/Widgets/BaseLayerPicker/lighter.css
Building Source/Widgets/lighter.css
Finished Source/Widgets/widgets.css
Building Source/Widgets/Viewer/Viewer.css
Finished Source/Widgets/shared.css
Building Source/Widgets/VRButton/VRButton.css
Finished Source/Widgets/lighterShared.css
Building Source/Widgets/Timeline/lighter.css
Finished Source/Widgets/lighter.css
Building Source/Widgets/Timeline/Timeline.css
Finished Source/Widgets/Viewer/Viewer.css
Building Source/Widgets/SelectionIndicator/SelectionIndicator.css
Finished Source/Widgets/Timeline/lighter.css
Building Source/Widgets/SceneModePicker/SceneModePicker.css
Finished Source/Widgets/VRButton/VRButton.css
Building Source/Widgets/PerformanceWatchdog/PerformanceWatchdog.css
Finished Source/Widgets/Timeline/Timeline.css
Building Source/Widgets/NavigationHelpButton/lighter.css
Finished Source/Widgets/SelectionIndicator/SelectionIndicator.css
Building Source/Widgets/NavigationHelpButton/NavigationHelpButton.css
Finished Source/Widgets/SceneModePicker/SceneModePicker.css
Building Source/Widgets/InfoBox/InfoBoxDescription.css
Finished Source/Widgets/PerformanceWatchdog/PerformanceWatchdog.css
Building Source/Widgets/InfoBox/InfoBox.css
Finished Source/Widgets/NavigationHelpButton/lighter.css
Building Source/Widgets/Geocoder/lighter.css
Finished Source/Widgets/InfoBox/InfoBoxDescription.css
Building Source/Widgets/Geocoder/Geocoder.css
Finished Source/Widgets/NavigationHelpButton/NavigationHelpButton.css
Building Source/Widgets/FullscreenButton/FullscreenButton.css
Finished Source/Widgets/InfoBox/InfoBox.css
Building Source/Widgets/CesiumWidget/lighter.css
Finished Source/Widgets/Geocoder/lighter.css
Building Source/Widgets/CesiumWidget/CesiumWidget.css
Finished Source/Widgets/FullscreenButton/FullscreenButton.css
Building Source/Widgets/CesiumInspector/CesiumInspector.css
Finished Source/Widgets/Geocoder/Geocoder.css
Finished Source/Widgets/CesiumWidget/lighter.css
Finished Source/Widgets/CesiumWidget/CesiumWidget.css
Finished Source/Widgets/CesiumInspector/CesiumInspector.css
[11:27:28] Finished ‘minifyRelease’ after 8.9 s
ezze@ezze-laptop:~/Development/cesium-bower/cesium$ ls ./Build/Cesium/
Assets Widgets
Hi!
I have some problems with “createTileMapServiceImageryProvider” after having replaced TileMapServiceImageryProvider.
This is the code:
var viewer = new Cesium.Viewer(‘cesiumContainer’ , {
imageryProvider : new Cesium.createTileMapServiceImageryProvider({
url : ‘//cesiumjs.org/tilesets/imagery/blackmarble’
baseLayerPicker : false,
navigationHelpButton : false,
clock : czml_clock,
globe : customGlobe,
vrButton : true
The result is in the picture attached.
Any suggestions?
Gianmaria
I was able to solve the issue with building by upgraing Node.js from 0.10 to 0.12.
I have no errors when I load Natural Earth. Probably, some other parameters for your Cesium Widget are wrong. See this as an example.
In my case imagery layer covers longitudes in [-Pi/2; Pi/2] only.
Seems that I use old Natural Earth cache so flipXY option set to true fixes the issue.
Hello Gianmaria,
What is your clock and custom globe?
Also, you need to use the flipXY setting for the black marble imagery. Here is an example:
imageryProvider : Cesium.createTileMapServiceImageryProvider({
url : ‘https://cesiumjs.org/blackmarble’,
credit : ‘Black Marble imagery courtesy NASA Earth Observatory’,
flipXY : true // Only old gdal2tile.py generated tilesets need this flag.
Hannah
I was unable to reproduce this issue. How are you adding the imagery?
Hannah
Thanks guys,
the flip solve the problem. Everything works!
Anyway here the code:
var czml_clock = new Cesium.Clock({
startTime : Cesium.currentTime,
currentTime : Cesium.currentTime,
clockRange : Cesium.ClockRange.LOOP_STOP,
clockStep : Cesium.ClockStep.SYSTEM_CLOCK_MULTIPLIER
var customGlobe = new Cesium.Globe();
url : ‘//cesiumjs.org/tilesets/imagery/naturalearthii’,
flipXY : true
clock : czml_clock,
vrButton : true
