Hello everyone,
We’re starting the CesiumJS 1.62 release process and it will be out later today.
Matt
Hello everyone,
Matt
CesiumJS 1.62 has been released: https://cesium.com/blog/2019/10/01/cesium-october-release/
After downloading I ran into permissions issues that don’t normally occur.
I discovered that the permissions on the /Build directory were 700 instead of the usual 775. Once I changed them to 775 then everything worked fine.
Thanks for pointing this out Matt. I guess you ran into it because part of your process is having a user different from the folder owner try to read it?
It looks like the gulpfile does try to set the correct file mode here:
But I can confirm running makeZipFile will create a build folder with read/write permission only for the owner.
Is there somewhere to view a list of closed issues for this release? Thank you.
The change log has a list of all the pull requests, which each should link to the issues they close:
https://github.com/AnalyticalGraphicsInc/cesium/blob/master/CHANGES.md#change-log
