Hello, I use cesium carthographic polygon to edit tileset material. I have made the material according to this tutorial. It works fine, but as you move around, zoom in or out, the map material changes and repeats itself, even though I changed the settings of the texture I use to clamp from wrap but the tiling keeps happening.
Here is the material layer blend blueprint:
I want the texture to be 1:1 size in the map, and I do not want the texture to tile and repeat. I want it to stay the same even if you zoom in or out. I would really appreciate it if you could help. (The image below is an example of what I want it to look like.)
