Certain calls to viewer.entities.add seem to have issues.
Safari: Works fine
Chrome and Firefox: Kills tab and sometimes causes a kernel panic that crashes my machine
It happens when I add the Citizens Bank stadium code snippet from "Points, Billboards, and Labels" at https://cesiumjs.org/tutorials/Visualizing-Spatial-Data/ to my own preexisting project. This issue also pops up with the Billboard code example at https://cesiumjs.org/Cesium/Build/Apps/Sandcastle/index.html?src=Billboards.html
I _think_ I've viewed this example in the past for older Cesium versions without running into any issues
I want to draw markers on a globe
Mac Sierra 10.12.6, tested using Safari 11.1, Chrome 67.0.3396.87, Firefox 60.0.2
Because the issue is inconsistent I'm not sure if it's a problem with Cesium itself or those specific browsers' WebGL implementations.
