Cesium Movie Render Loading Time
I have read lots of forums to look for a solution for the movie render queue but with no luck.
My problem is when I do an animate sequence, the first 10 frames are the loading time of the 3D tiles. Is there a way to load first the entire tiles in the scene as a warmup before the first frame to render?
Thank you.
Hi @Humbertlsk,
In general, no, it’s not possible to load an entire tileset prior to starting a sequence. In the general case, that could require downloading many terabytes of data!
When Cesium for Unreal detects that it is running inside a Level Sequence, it will automatically switch to a mode where it loads everything needed for each frame before allowing that frame to be snapped. This usually solves the problem for video rendering, at least. The trick is that it can only tell it’s inside a Level Sequence if the sequence is actually in your level. If it’s just an asset in your content browser, it won’t work.
