Hey, I have been playing around using Cesium. I would like to try to render out and export a sequence. When I try to use the movie render queue, everything shows up except my cesium map. I wanted to know is there anything I can do?
Is your warmup frame count zero? The tileset needs some time to load into the scene, so having some warmup frames is necessary for it to show at the beginning of the sequence.
It may also be that you added the level sequence using the “Content Browser”, which creates the sequence as an asset. The level sequence must be added to the level itself to work. See Kevin’s post below.
There are many many threads on this topic recently, so please have a look. If none of them help, please post detailed instructions to help us reproduce your particular problem, preferably starting with the Cesium for Unreal Samples project.
