Hi!
Scene shows up fine in editor, but when trying to render out, no map data shows up, and rendering freezes on frame 0.
I have added the sequence to the scene and have used 32 warmup frames for both sequence and engine.
Hi!
How long have you waited? If you’re rendering at high resolution, it can take a little while to load the data for that first frame.
But if that’s not it, you’ll need to help us reproduce this problem ourselves before we can debug it. Please provide detailed step-by-step instructions, preferably starting with the Cesium for Unreal Samples project.
Thanks for answering!
I was too impatient - it started to render after about 30 minutes or so. Wierd, because the editor rendered map data quickly.
