Exactly as the title suggests, I have to process data for 5 DataSources (CZML) every second. The Data is positional data totaling approximately 50-100 Cartesian LatLong Points, that are referenced by 10-50 polygons, that represent 2-10 3D shapes.
Sorry thats a mouthful. Every time I process the data (every second), it lags about 100ms (in the beginning, which is okay), and after 5mins 600ms (which is a problem).
I attached a profiler screenshot for reference.
After some initialization I run:
timeInterval = setInterval(processNext, 1000);
This trigger the following function (extraneous bits cut out):
//Process Data into CZML -> from JSON
function processNext() {
var xhttp4 = new XMLHttpRequest();
xhttp4.onreadystatechange = function() {
if (xhttp4.readyState === 4) {
// Execute two functions upon recieving data
//add records to relevant data set
xhttp4.response.forEach(function(element) {
if (current.data.id === "layer3") {
//DS_layer3.process(objects);
else if (current.data.id === "layer2") {
//console.log("layer2");
//console.log(current);
if (current.data.camera_id === 1) {
convertboxheight(current);
bounding_boxes[13].position.cartographicDegrees.push(tempISO, current.data.bounding_boxes[0].v0.x, current.data.bounding_boxes[0].v0.y, current.data.bounding_boxes[0].v0.z);
//Do for 8 Vertices
if (boxC.count > 50 ){
//prevent Cmzl from getting too big and slowing down? -> idk if this actually happens.
bounding_boxes[13].position.cartographicDegrees.splice(0, 4);
//Also do for 8 Vertices
boxC.count++;
else if (current.data.camera_id === 2) {
//Do same thing as camera 1
DS_layer2.process(bounding_boxes);
else if (current.data.id === "layer1") {
//Process More Data, same format as above
DS_layer1.process(camera_data);
//move timestamp forward --> doing this after adding records
prevTime.time = prevTime.time + 1000;
xhttp4.responseType = 'json';
xhttp4.open("GET", "URLtoAPI" );
So is there anyway to optimize this Code or do it in a way that doesn’t take 600ms to Process?
System is HP zBook with Quadro 2000M running on Google Chrome
