I’m really new to CesiumJS and am trying to go through the quick start exercise and running into several problems. I have the cesium package saved locally in my working directory and on step 2 of the guide where we try to setup the CesiumJS client I copied over the section of code from the “Install with NPM” section but I seem to not be able to run the client from my HTML file. I set the base CESIUM_BASE_URL to the directory containing the 4 other directories as instructed, assigned the path to the widgets.css file to the one now stored locally on my workspace, and applied my access token. I find that when I call the js file from my html file as a script and open said html file nothing appears in it. What could I be doing wrong? Thank you.
I found the quickstart guide to be a bit confusing, I ended up spending a lot of time on setting up Cesium (using both CDN and npm) instead of focusing on the API documentation and other features.
A humble suggestion to Cesium. Please rewrite the quick start so it easy for beginners. A would also recommend that you explain more on npm installation. Maybe a video tutorial would be helpful.
