About the value of ActivationRadius in Cesium Sub Scene, what is its maximum value in general
There shouldn’t be any particular maximum value. But only the single closest sub-scene will be activated at any given time.
I want to set only one subscene, and set its ActivationRadius value to be large enough to cover the earth. Is that OK
I don’t think the subscene will be doing much for you in that scenario. But it shouldn’t cause any problems either. Can I ask why you want to do that?
I want to generate many objects according to the latitude and longitude in the scene through the code. The latitude and longitude of these objects involve a large range, if I have multiple sub-scenes, I don’t know which sub-scene is the parent object of these code generated objects
I have a question about object generation in code. How can I instantiate an object in the scene from the latitude and longitude coordinates, and ask that this object is on the ground in Cesium map, as if height 0 does not mean that it is on the ground
Ok, sure, but you can just avoid using any subscenes.
How can I instantiate an object in the scene from the latitude and longitude coordinates…
I answered this in your other thread.
