I am getting this error using this: new Cesium.IonImageryProvider({ assetId: 3954 }) but I am also noting it in cesium sandcastle viewer when switching to Bing Aerial with labels or street which use the same path “/v1/assets…”
Thanks for reporting @maarondesigns! This should be fixed now. Can you confirm?
I am still getting a 404 error but I see those same endpoints are working in the sandcastle. Maybe it is an issue with my access token? I tried hard reloading my site in case it was some kind of caching issue but that did not work. Maybe caching on cesium’s server side?..
Ok, that means you’re not subscribed to those assets. Go to https://cesium.com/ion/assetdepot/ and make sure you’re subscribed to those layers.
That’s odd. I am pretty sure I did that already but I just did again and now it is working. Thanks!
I am also facing the same issue
