Cesium Viewer not loading
I am a new cesium user and have been reading an implementing the code given in the workshop. Initially there was no problem in loading the cesium viewer using the code given in APP.JS but now barring cesium viewer rest all is visible.
Kindly adhere to this problem asap.
version:1.38 browser: chrome OS: Windows 8.1,8GB RAM,i5 processor
Hi there,
You mean the Cesium Workshop tutorial correct? Can you give us more details about the problem? Do you have an error message?
Gabby
Yeah, I mean cesium workshop tutorial. I want to modify my problem. The cesium viewer is loading but bingmaps imagery is not getting added on the viewer, rest of all the imagery layers are getting added. I wonder whether it has something to do with the bing maps key.
You are correct, it does seem to be the Bing key. You can (and should!) generate your own here: https://www.bingmapsportal.com/
I’ll make a note to update that tutorial accordingly.
Gabby
