Cesium has worked fine for me in the past, but about two weeks ago, every single browser on my PC that used Cesium did not show any of the land. A few of the programs that I use/play on that no longer show the land are: GEFS-Online, Flightradar24, and EarthClock.
It sounds like these apps may be using our default bing maps API key for the imagery. This rotates frequently and when it expires, the imagery no longer loads.
While we make a key available for testing out Cesium, we require users to key their own Bing API key before bringing their application into production.
You can learn more about how to do this here: http://cesiumjs.org/Cesium/Build/Documentation/BingMapsApi.html
Hannah
Ok. I play GEFS-Online. How would I create the key for this website?
Just so you guys know I'm not a developer for making programs using Cesium. I only play games made on it so the Key is not what I need
Do you also see the same issue when clicking Tap To Interact on http://cesiumjs.org/?
yep
Sorry that you’re still having this problem, but from our discussion before your network is failing to load from the imagery server, and that is out of Cesium’s control. One thing I forgot to ask before, are you using any special chrome extensions that might be interfering?
