I'm displaying a point cloud for some transmission lines, but whenever I have more than 27 classification colors, the Cesium viewer crashes. Could this be from a memory leak of some sort in my viewer that I need to fix, or the tileset being too large? Just adding one more classification color crashes the viewer on the same tileset.
The errors read as follows:
In the UI: RuntimeError: Error generating style shader: this may be caused by a type mismatch, index out-of-bounds, or other syntax error.
In the console: [Cesium WebGL] Vertex shader compile log: ERROR: 0:121: '{' : memory exhausted
[Cesium WebGL] Vertex shader translation failed.
I'm using Cesium3DTilesets using styles define by Cesium3DTileStyle objects.
I've structured the colors using RGB's based upon the classification for each point, in the following format:
new Cesium.Cesium3DTileStyle({
color: {
conditions: [
["${Classification} === 0", "rgba(255, 0, 0, 1.0)"], // Created, never classified
If the conditions array has more than 27 classification colors, then I get the error upon loading the point cloud.
I've found that an alternate solution is to consolidate the colors with the following syntax:
["\{Classification\} >= 19 && {Classification} <= 63", "rgba(110, 100, 25, 1.0)"]
We're trying to show vegetation encroachment upon transmission lines, using the colors to help identify different objects in the viewer.
Cesium version 1.52.0
MacOS Sierra
Chrome 71.0.3578.98
