Have you loaded 3GB 3dtiles in cesium? Chrome crashed
I have osgb files for a city, and converted to 3dtiles with a tool: https://github.com/fanvanzh/3dtiles .
When I load it in cesium, I can see Chrome loads some tiles and soon crashed, is it too big for memory?
I use this in an offline environment, so IO is not a choice.
I used these codes to fix a KHR_technique_webgl issue, is that the problem?
var fixGltf = function(gltf) {
if (!gltf.extensionsUsed) {
return;
var v = gltf.extensionsUsed.indexOf(“KHR_technique_webgl”);
var t = gltf.extensionsRequired.indexOf(“KHR_technique_webgl”);
// 中招了。。
if (v !== -1) {
gltf.extensionsRequired.splice(t, 1, “KHR_techniques_webgl”);
gltf.extensionsUsed.splice(v, 1, “KHR_techniques_webgl”);
gltf.extensions = gltf.extensions || {};
gltf.extensions[“KHR_techniques_webgl”] = {};
gltf.extensions[“KHR_techniques_webgl”].programs = gltf.programs;
gltf.extensions[“KHR_techniques_webgl”].shaders = gltf.shaders;
gltf.extensions[“KHR_techniques_webgl”].techniques = gltf.techniques;
var techniques = gltf.extensions[“KHR_techniques_webgl”].techniques;
gltf.materials.forEach(function(mat, index) {
gltf.materials[index].extensions[“KHR_technique_webgl”].values =
gltf.materials[index].values;
gltf.materials[index].extensions[“KHR_techniques_webgl”] =
gltf.materials[index].extensions[“KHR_technique_webgl”];
var vtxfMaterialExtension =
gltf.materials[index].extensions[“KHR_techniques_webgl”];
for (var value in vtxfMaterialExtension.values) {
var us = techniques[vtxfMaterialExtension.technique].uniforms;
for (var key in us) {
if (us[key] === value) {
vtxfMaterialExtension.values[key] =
vtxfMaterialExtension.values[value];
delete vtxfMaterialExtension.values[value];
break;
techniques.forEach(function(t) {
for (var attribute in t.attributes) {
var name = t.attributes[attribute];
t.attributes[attribute] = t.parameters[name];
for (var uniform in t.uniforms) {
var name = t.uniforms[uniform];
t.uniforms[uniform] = t.parameters[name];
Object.defineProperties(Cesium.Model.prototype, {
_cachedGltf: {
set: function(value) {
this._vtxf_cachedGltf = value;
if (this._vtxf_cachedGltf && this._vtxf_cachedGltf._gltf) {
fixGltf(this._vtxf_cachedGltf._gltf);
get: function() {
return this._vtxf_cachedGltf;
When I reduce the 3dtiles data, cesium worked well
在 2019年1月4日星期五 UTC+8下午4:48:34,Yang写道:
I’ve seen tilesets much larger than that load fine, since lower levels of detail and only loading what’s in view ensure there’s never too much loaded at any given time.
I know you said you need this for an offline environment, but just to confirm my suspicion, can you try tiling it with Cesium ion (https://cesium.com/ion/) and see if that tileset works fine? If it does, there are offline versions of ion’s tools (https://cesium.com/docs/on-prem/). If it doesn’t, then it’s definitely an issue on our end and something we can look into and fix.
You might also try to increase the amount of memory for chrome.
Scott
