When I am in play mode in the editor the tiles render fine. The moment I package a build and try to load the level with the cesium tile it is just blank.
Here is what I found in the logs:
[2023.12.14-21.39.05:833][267]LogHttp: Warning: 00000234AE6D4BD0: request failed, libcurl error: 60 (SSL peer certificate or SSH remote key was not OK)
[2023.12.14-21.39.05:833][267]LogHttp: Warning: 00000234AE6D4BD0: libcurl info message cache 0 ( Trying 18.160.213.44:443...)
[2023.12.14-21.39.05:833][267]LogHttp: Warning: 00000234AE6D4BD0: libcurl info message cache 1 (Connected to api.cesium.com (18.160.213.44) port 443 (#0))
[2023.12.14-21.39.05:833][267]LogHttp: Warning: 00000234AE6D4BD0: libcurl info message cache 2 (ALPN: offers http/1.1)
[2023.12.14-21.39.05:833][267]LogHttp: Warning: 00000234AE6D4BD0: libcurl info message cache 3 (TLSv1.3 (OUT), TLS handshake, Client hello (1):)
[2023.12.14-21.39.05:833][267]LogHttp: Warning: 00000234AE6D4BD0: libcurl info message cache 4 (TLSv1.3 (IN), TLS handshake, Server hello (2):)
[2023.12.14-21.39.05:833][267]LogHttp: Warning: 00000234AE6D4BD0: libcurl info message cache 5 (TLSv1.3 (IN), TLS handshake, Encrypted Extensions (8):)
[2023.12.14-21.39.05:833][267]LogHttp: Warning: 00000234AE6D4BD0: libcurl info message cache 6 (TLSv1.3 (IN), TLS handshake, Certificate (11):)
[2023.12.14-21.39.05:833][267]LogHttp: Warning: 00000234AE6D4BD0: libcurl info message cache 7 (TLSv1.3 (OUT), TLS alert, unknown CA (560):)
[2023.12.14-21.39.05:833][267]LogHttp: Warning: 00000234AE6D4BD0: libcurl info message cache 8 (SSL certificate problem: unable to get local issuer certificate)
[2023.12.14-21.39.05:833][267]LogHttp: Warning: 00000234AE6D4BD0: libcurl info message cache 9 (Closing connection 0)
[2023.12.14-21.39.05:838][267]LogCesium: Error: [2023-12-14 21:39:05.839] [error] [TilesetContentManager.cpp:825] An unexpected error occurred when loading tile: Request failed.
Edit: So I tested the build in a different environment and the Cesium Terrain shows up on that one but not on the computer that I need it to work on. I am not sure where to look to find the root cause…
