Hi
I want to change the color of buildings in my project.
https://github.com/shahabshafiee/gewiss
So far changing the color in each tile is done.
I used web-map-client solution from Munich university.
Hi
If you are using 3D tiles, you can try using declarative styling. You lean learn more about 3D tiles styling here: https://github.com/AnalyticalGraphicsInc/3d-tiles/blob/master/Styling/README.md
If you are not familiar with the 3D tiles format, you can learn more about it in this forum post: https://groups.google.com/d/msg/cesium-dev/tCCooBxpZFU/7hxT_E4pGgAJ
Hannah
Dear Hannah,
I am using 3dcitydb-web-map.
I already tried some of the files in that package but so far I can only change the color of a “tile”.
Is there a way that I can directly use Cesium instead of 3dcitydb-web-map?
Regards,
Shahab
