Using the mouse to draw an ArcType.RHUMB Polygon around the pole results in the browser becoming unresponsive. To help recreate, attached is a screen capture of the polygon just after the browser freeze.
imageryProvider: new Cesium.IonImageryProvider({ assetId: 3845 })
viewer.screenSpaceEventHandler.removeInputAction(Cesium.ScreenSpaceEventType.LEFT_CLICK);
viewer.screenSpaceEventHandler.removeInputAction(Cesium.ScreenSpaceEventType.LEFT_DOUBLE_CLICK);
var scene = viewer.scene;
var camera = viewer.camera;
var polyline;
var polygon;
var drawing = false;
var positions = ;
var points = ;
var handler = new Cesium.ScreenSpaceEventHandler(viewer.canvas);
handler.setInputAction(
function (click) {
var clickPosition = viewer.camera.pickEllipsoid(click.position || click.endPosition, viewer.scene.globe.ellipsoid);
if (!drawing) {
drawing = true;
viewer.entities.remove(polyline);
viewer.entities.remove(polygon);
for (var i = 0; i < points.length; i++) {
viewer.entities.remove(points[i]);
points = ;
positions = ;
positions.push(clickPosition);
drawPoint(clickPosition);
function (click) {
drawing = !drawing;
}, Cesium.ScreenSpaceEventType.LEFT_DOUBLE_CLICK);
function (movement) {
if (drawing && positions.length > 0) {
var mousePosition = viewer.camera.pickEllipsoid(movement.position || movement.endPosition, viewer.scene.globe.ellipsoid);
if (mousePosition) {
if (positions.length === 1) {
drawPolyline([positions[0], mousePosition]);
var copy = positions.slice();
copy.push(mousePosition);
drawPolygon(copy);
function drawPoint(position) {
var point = new Cesium.Entity({
position : position,
point: {
pixelSize: 5,
color: Cesium.Color.WHITE,
outlineColor: Cesium.Color.BLACK,
outlineWidth: 1,
viewer.entities.add(point);
points.push(point);
function drawPolygon(positions) {
polygon = viewer.entities.add({
polygon: {
hierarchy: new Cesium.CallbackProperty(function() {
return new Cesium.PolygonHierarchy(positions);
}, false),
material: Cesium.Color.POWDERBLUE.withAlpha(0.4),
outline: true,
outlineWidth: 1,
height: 0,
arcType: Cesium.ArcType.RHUMB,
function drawPolyline(positions) {
polyline = viewer.entities.add({
polyline : {
positions : new Cesium.CallbackProperty(function() {
return positions;
}, false),
material : Cesium.Color.BLUE,
width : 5,
// adding help text
var paragraph0 = document.createElement(‘p’);
paragraph0.id = ‘help0’;
var node0 = document.createTextNode("To start drawing, left click and move mouse. ");
paragraph0.appendChild(node0);
var paragraph1 = document.createElement(‘p’);
paragraph1.id = ‘help1’;
var node1 = document.createTextNode("Left double click to stop drawing. ");
paragraph1.appendChild(node1);
var element = document.getElementById(‘toolbar’);
element.appendChild(paragraph0);
element.appendChild(paragraph1);
document.getElementById(‘help0’).style.fontSize = ‘16px’;
document.getElementById(‘help1’).style.fontSize = ‘16px’;
We have a requirement to allow the user to use the mouse to draw a polygon with ArcType RHUMB. This works perfectly except around the poles.
Cesium 1.61
Windows 10
Chrome Version 76.0.3809.100 (Official Build) (32-bit)
Firefox Developer Edition 66.0b14 (64-bit)
