Using the mouse, I am unable to draw a Polyline with an ArcType of RHUMB.
imageryProvider: new Cesium.IonImageryProvider({ assetId: 3845 })
viewer.screenSpaceEventHandler.removeInputAction(Cesium.ScreenSpaceEventType.LEFT_CLICK);
viewer.screenSpaceEventHandler.removeInputAction(Cesium.ScreenSpaceEventType.LEFT_DOUBLE_CLICK);
var scene = viewer.scene;
var camera = viewer.camera;
var polyline;
var drawing = false;
var positions = ;
var firstClick = null;
var handler = new Cesium.ScreenSpaceEventHandler(viewer.canvas);
handler.setInputAction(
function (click) {
var clickPosition = viewer.camera.pickEllipsoid(click.position || click.endPosition, viewer.scene.globe.ellipsoid);
if (!firstClick) {
firstClick = clickPosition;
positions.push(clickPosition);
if (drawing) {
firstClick = null;
positions = [];
drawing = !drawing;
function (movement) {
var mousePosition = viewer.camera.pickEllipsoid(movement.position || movement.endPosition, viewer.scene.globe.ellipsoid);
if (drawing) {
// remove previous line
viewer.entities.remove(polyline);
positions = [];
positions.push(firstClick);
positions.push(mousePosition);
draw(positions);
function draw(currentPositions) {
polyline = viewer.entities.add({
polyline : {
positions : new Cesium.CallbackProperty(function() {
return currentPositions;
}, false),
material : Cesium.Color.BLUE,
width : 5,
arcType: Cesium.ArcType.RHUMB
// adding help text
var paragraph0 = document.createElement(‘p’);
paragraph0.id = ‘help0’;
var node0 = document.createTextNode("To start drawing, left click and move mouse. ");
paragraph0.appendChild(node0);
var paragraph1 = document.createElement(‘p’);
paragraph1.id = ‘help1’;
var node1 = document.createTextNode("Left click again to stop drawing. ");
paragraph1.appendChild(node1);
var element = document.getElementById(‘toolbar’);
element.appendChild(paragraph0);
element.appendChild(paragraph1);
document.getElementById(‘help0’).style.fontSize = ‘16px’;
document.getElementById(‘help1’).style.fontSize = ‘16px’;
We have a requirement to allow the user to define a region by drawing a Polygon with ArcType RHUMB using the mouse. We are doing that successfully. Between the first mouse and second mouse clicks, as the mouse is being moved, we draw a line to show to the user the region. As we draw that initial line, however, as it does not seem to apply ArcType.RHUMB, it does not accurately represent the eventual shape of the polygon.
Cesium 1.61
Windows 10
Chrome Version 76.0.3809.100 (Official Build) (32-bit)
Firefox Developer Edition 66.0b14 (64-bit)
