Error when trying to add entities to Cesium.CesiumWidget
I am trying to add an entity in a Cesium.CesiumWidget, through its entities collection but I get the following error:
TypeError: Cannot read property 'add' of undefined
I am actually trying to reproduce the Camera demo from Sandcastle but instead of using the standard Viewer, I try to use the Widget Viewer. Below is my src code:
var viewer = new cesium.CesiumWidget('cesiumContainer');
var west = -77.0;
var south = 38.0;
var east = -72.0;
var north = 42.0;
var rectangle = Cesium.Rectangle.fromDegrees(west, south, east, north);
    viewer.camera.setView({
        destination: rectangle
// Show the rectangle. Not required; just for show.
    viewer.entities.add({
        rectangle : {
            coordinates : rectangle,
            fill : false,
            outline : true,
            outlineColor : Cesium.Color.WHITE
I use:
- Cesium 1.19
- Windows 10 Enterprise
- Google Chrome 49.0.2623.87 m
This code is meant to use the Viewer, not the CesiumWidget.
Replace the first line of your example with
Hannah
Isn't it possible to add entities using the widget in any way?
Hi Hannah,
I finally tried to add some entities as stated in this thread.
https://groups.google.com/forum/embed/?place=forum/cesium-dev&showsearch=true&showpopout=true&hideforumtitle=true&fragments=true&parenturl=http%3A%2F%2Fcesiumjs.org%2Fforum.html#!searchin/cesium-dev/CesiumWidget/cesium-dev/2MQk1VNecWs/dgBlwqdABgAJ
Thank you for your reply!
