Error while trying to code a custom ellipsoid terrain provider
Hello
As a followup of Ellipsoid Terrain I am beginning to create an EllipsoidTerrainProvider. This will imply at least modifying the cpp code of Unity and I am usuccesfull right now.
The first step I would like to do is do a simple MonoBehaviour linked to cpp that logs at each update a message
In order to do that I created the following CesiumEllipsoidTerrainProvider.cs in CesiumForUnity/Runtime
using Reinterop;
using System;
using UnityEngine;
namespace CesiumForUnity
    [ExecuteInEditMode]
    [ReinteropNativeImplementation("CesiumForUnityNative::CesiumEllipsoidTerrainProviderImpl", "CesiumEllipsoidTerrainProviderImpl.h")]
    public class CesiumEllipsoidTerrainProvider : MonoBehaviour, IDisposable, ISerializationCallbackReceiver
        public void Dispose()
        public void OnAfterDeserialize()
        public void OnBeforeSerialize()
Then the CesiumEllipsoidTerrainProviderImpl.h in native~/Runtime/src
#pragma once
#include <Cesium3DTilesSelection/ViewUpdateResult.h>
#include <DotNet/CesiumForUnity/CesiumCreditSystem.h>
#include <DotNet/CesiumForUnity/CesiumGeoreference.h>
#include <DotNet/System/Action.h>
#include <memory>
#if UNITY_EDITOR
#include <DotNet/UnityEditor/CallbackFunction.h>
#endif
namespace DotNet::CesiumForUnity {
class CesiumEllipsoidTerrainProvider;
class CesiumCreditSystem;
} // namespace DotNet::CesiumForUnity
namespace Cesium3DTilesSelection {
class Tileset;
namespace CesiumForUnityNative {
class CesiumEllipsoidTerrainProviderImpl {
public:
CesiumEllipsoidTerrainProviderImpl(const DotNet::CesiumForUnity::CesiumEllipsoidTerrainProvider& tileset);
~CesiumEllipsoidTerrainProviderImpl();
void Start(const DotNet::CesiumForUnity::CesiumEllipsoidTerrainProvider& tileset);
void Update(const DotNet::CesiumForUnity::CesiumEllipsoidTerrainProvider& tileset);
void OnValidate(const DotNet::CesiumForUnity::CesiumEllipsoidTerrainProvider& tileset);
void OnEnable(const DotNet::CesiumForUnity::CesiumEllipsoidTerrainProvider& tileset);
void OnDisable(const DotNet::CesiumForUnity::CesiumEllipsoidTerrainProvider& tileset);
} // namespace CesiumForUnityNative
Then the CesiumEllipsoidTerrainProviderImpl.cpp in native~/Runtime/src
#include "CesiumEllipsoidTerrainProviderImpl.h"
#include "CameraManager.h"
#include "CesiumIonServerHelper.h"
#include "UnityPrepareRendererResources.h"
#include "UnityTileExcluderAdaptor.h"
#include "UnityTilesetExternals.h"
#include <Cesium3DTilesSelection/IonRasterOverlay.h>
#include <Cesium3DTilesSelection/Tileset.h>
#include <CesiumGeospatial/GlobeTransforms.h>
#include <CesiumIonClient/Connection.h>
#include <DotNet/CesiumForUnity/Cesium3DTileset.h>
#include <DotNet/CesiumForUnity/Cesium3DTilesetLoadFailureDetails.h>
#include <DotNet/CesiumForUnity/Cesium3DTilesetLoadType.h>
#include <DotNet/CesiumForUnity/CesiumDataSource.h>
#include <DotNet/CesiumForUnity/CesiumIonServer.h>
#include <DotNet/CesiumForUnity/CesiumRasterOverlay.h>
#include <DotNet/CesiumForUnity/CesiumTileExcluder.h>
#include <DotNet/System/Array1.h>
#include <DotNet/System/Object.h>
#include <DotNet/System/String.h>
#include <DotNet/UnityEngine/Application.h>
#include <DotNet/UnityEngine/Camera.h>
#include <DotNet/UnityEngine/Debug.h>
#include <DotNet/UnityEngine/Experimental/Rendering/FormatUsage.h>
#include <DotNet/UnityEngine/Experimental/Rendering/GraphicsFormat.h>
#include <DotNet/UnityEngine/GameObject.h>
#include <DotNet/UnityEngine/Material.h>
#include <DotNet/UnityEngine/Object.h>
#include <DotNet/UnityEngine/Quaternion.h>
#include <DotNet/UnityEngine/SystemInfo.h>
#include <DotNet/UnityEngine/Time.h>
#include <DotNet/UnityEngine/Transform.h>
#include <DotNet/UnityEngine/Vector3.h>
#include <variant>
#if UNITY_EDITOR
#include <DotNet/UnityEditor/EditorApplication.h>
#include <DotNet/UnityEditor/EditorUtility.h>
#include <DotNet/UnityEditor/SceneView.h>
#endif
using namespace Cesium3DTilesSelection;
using namespace DotNet;
CesiumEllipsoidTerrainProviderImpl::CesiumEllipsoidTerrainProviderImpl(
CesiumEllipsoidTerrainProviderImpl::~CesiumEllipsoidTerrainProviderImpl() {}
void CesiumEllipsoidTerrainProviderImpl::Start(
const DotNet::CesiumForUnity::CesiumEllipsoidTerrainProvider& tileset) {}
void CesiumEllipsoidTerrainProviderImpl::Update(
void CesiumEllipsoidTerrainProviderImpl::OnValidate(
void CesiumEllipsoidTerrainProviderImpl::OnEnable(
void CesiumEllipsoidTerrainProviderImpl::OnDisable(
The code compiles using cmake and I regenerate the interop.
However I have the following error in Unity
NotImplementedException: The native implementation is missing so Update cannot be invoked. This may be caused by a missing call to CreateImplementation in one of your constructors, or it may be that the entire native implementation shared library is missing or out of date.
CesiumForUnity.Cesium3DTileset.Update () (at ./Reinterop/Reinterop.RoslynSourceGenerator/Cesium3DTileset-generated.cs:85)
Do you have an idea of what could be missing ?
Could you point me on some documentation about the techniques you are using for the interop ?
Thanks and regards
Hi @carlopiersanti,
It sounds like you may have missed the “Build for the Editor” step of the Developer Setup? After you generate the reinterop files, you still have to build them with the C++ implementation files using cmake. But let us know if you’ve done that step and you’re still having issues.
Ok many things were wrong :
  • Class needs to be partial and at least expose one method that will be implemented on cpp otherwise interop won’t trigger
  • Internal log method must be called in dummy code ConfigureReinterop otherwise code won’t be generated
  • I had to close unity between each step and build Reinterop before building the code (I was doing the opposite)
Thanks for your support and regards
