Failed import for Cesium
I’m getting this Load Error on my project’s startup, and it’s also now causing packaging problems. There’s no file in the folder that it’s pointing to. Anyone know what’s going on?
Aidan
Hi @aidnewsome,
Sorry for the delayed response. I’m not sure what is going on based on the errors alone. Perhaps it has something to do with how your level is set up? It would help if you share a screenshot of your Outliner panel, so we can see what objects are in it.
It could also be worth downloading and packaging the Cesium for Unreal Samples project, just to confirm if this baseline works for you:
Thanks!
