Whenever I open a file that is using Cesium I get an error:
Failed import for CesiumSunSky
I added then deleted CesiumSunSky before, and then afterwards I updated the file from UE5.3 to 5.4.
Any ideas how to get rid of it?
Hi @thmm,
It looks like it’s failing trying to import an “external actor” from your level. I don’t know how to solve your particular problem, because I don’t know why it’s failing to import the external actor in your particular project. But it might help to read up on how external actors work:
https://dev.epicgames.com/documentation/en-us/unreal-engine/one-file-per-actor-in-unreal-engine
hi Kevin,
Thanks for the quick reply. I did try to check the folder for external actors and the directory the error is referring to is not there… I will read on and find out which entry or setting is actually making the call to it.
Cheers!
I basically just disabled External Actors in World Settings tab.
I’m not working in collaboration anyways.
Hope that helps someone!
