Hi Cesium community,
I’m trying to programmatically access a Cesium Ion tileset using cpp-httplib (a lightweight C++ HTTP library), but I keep getting a connection error(testHttps2 failed). The same request works perfectly with curl, so I suspect the issue lies in how I’m configuring the HTTPS client in C++.
Target URL & Token
Tileset URL:
https://assets.ion.cesium.com/ap-northeast-1/asset_depot/3644333/Mars/v2/tileset.json?v=2 -
Access Token: Valid short-lived JWT (expires in 1 hour)
What Works: curl Command
curl "https://assets.ion.cesium.com/ap-northeast-1/asset_depot/3644333/Mars/v2/tileset.json?v=2" \
-H "Authorization: Bearer <MY_TOKEN>" \
-H "Accept: application/json"
→ Returns valid tileset.json (HTTP 200).
What Fails: cpp-httplib (v0.20.0)
I’m using cpp-httplib 0.20.0 with OpenSSL 1.1.1w on Windows (MSVC). Here’s my simplified code:
#define CPPHTTPLIB_OPENSSL_SUPPORT
#include "httplib.h"
#include <iostream>
#include <string>
#include <map>
#include <chrono>
#include <thread>
#include <nlohmann/json.hpp>
using json = nlohmann::json;
void testHttps1();
void testHttps2(const std::string &targetUrl, const std::string &accessToken);
void testHttps2Alternative(const std::string &targetUrl, const std::string &accessToken);
bool parseCesiumResponse(const std::string &responseBody, std::string &outUrl, std::string &outToken);
bool parseFullUrl(const std::string &url, std::string &outProtocol, std::string &outHost, int &outPort, std::string &outPath);
int main()
std::cout << "=== Step 1: Get Cesium Asset Endpoint ===" << std::endl;
testHttps1();
return 0;
void testHttps1()
const std::string host = "api.cesium.com";
const int port = 443;
const std::string path = "/v1/assets/3644333/endpoint?access_token=<MY_TOKEN>";
const std::map<std::string, std::string> headers = {
{"User-Agent", "CesiumConnectionTester/1.0"},
{"Accept", "application/json"}};
std::cout << "Requesting: https://" << host << path << std::endl
<< std::endl;
httplib::SSLClient client(host, port);
client.enable_server_certificate_verification(false);
client.set_connection_timeout(30);
client.set_read_timeout(120);
client.set_write_timeout(30);
httplib::Headers httplibHeaders;
for (const auto &[key, value] : headers)
httplibHeaders.emplace(key, value);
auto start = std::chrono::steady_clock::now();
auto response = client.Get(path, httplibHeaders);
auto end = std::chrono::steady_clock::now();
auto duration = std::chrono::duration_cast<std::chrono::milliseconds>(end - start);
if (response)
std::cout << "=== Step 1 Response ===" << std::endl;
std::cout << "Status code: " << response->status << std::endl;
std::cout << "Time taken: " << duration.count() << " ms" << std::endl
<< std::endl;
std::cout << "Response body:" << std::endl;
std::cout << response->body << std::endl
<< std::endl;
std::string nestedUrl, tempToken;
if (parseCesiumResponse(response->body, nestedUrl, tempToken))
std::cout << "=== Step 1 Parse Success ===" << std::endl;
std::cout << "Extracted nested URL: " << nestedUrl << std::endl;
std::cout << "Extracted temp access token: " << tempToken << std::endl
<< std::endl;
std::cout << "=== Step 2: Request Nested Cesium Asset URL ===" << std::endl;
testHttps2(nestedUrl, tempToken);
// testHttps2Alternative(nestedUrl, tempToken);
else
std::cout << "=== Step 1 Parse Failed: Cannot extract URL or token ===" << std::endl;
else
std::cout << "=== Step 1 Request Failed ===" << std::endl;
std::cout << "Error: " << httplib::to_string(response.error()) << std::endl;
std::cout << "Time taken: " << duration.count() << " ms" << std::endl;
if (targetUrl.empty() || accessToken.empty())
std::cout << "Invalid parameters: URL or token is empty" << std::endl;
return;
std::string protocol, host;
int port;
std::string path;
if (!parseFullUrl(targetUrl, protocol, host, port, path))
std::cout << "Invalid URL format: " << targetUrl << std::endl;
return;
if (protocol != "https")
std::cout << "Unsupported protocol: " << protocol << " (only HTTPS is supported)" << std::endl;
return;
client.set_keep_alive(false);
{"User-Agent", "curl/7.88.1"},
{"Accept", "application/json"},
{"Authorization", "Bearer " + accessToken}};
std::cout << "Requesting nested URL: " << targetUrl << std::endl;
if (response)
std::cout << "=== Step 2 Response ===" << std::endl;
<< std::endl;
std::cout << "Response headers:" << std::endl;
for (const auto &[key, value] : response->headers)
std::cout << key << ": " << value << std::endl;
std::cout << std::endl
<< "Response body (tileset.json):" << std::endl;
if (response->body.size() > 2000)
std::cout << response->body.substr(0, 2000) << "..." << std::endl;
std::cout << "(Response body truncated, total size: " << response->body.size() << " bytes)" << std::endl;
else
std::cout << response->body << std::endl;
else
std::cout << "=== Step 2 Request Failed ===" << std::endl;
std::cout << "Error type: " << httplib::to_string(response.error()) << std::endl;
std::cout << "Possible reasons:" << std::endl;
std::cout << " 1. SSL handshake failed (check OpenSSL version)" << std::endl;
std::cout << " 2. Connection closed by server (check keep-alive config)" << std::endl;
std::cout << " 3. Invalid token or URL (verify with curl first)" << std::endl;
std::cout << "=== Trying alternative method using system curl ===" << std::endl;
std::string cmd = "curl -s -H \"Authorization: Bearer " + accessToken + "\" ";
cmd += "-H \"User-Agent: curl/8.14.1\" ";
cmd += "-H \"Accept: */*\" ";
cmd += "\"" + targetUrl + "\"";
std::cout << "Executing: " << cmd << std::endl;
int result = system(cmd.c_str());
if (result == 0)
std::cout << "Curl command executed successfully" << std::endl;
else
std::cout << "Curl command failed with code: " << result << std::endl;
try
json responseJson = json::parse(responseBody);
outUrl = responseJson["url"];
outToken = responseJson["accessToken"];
return !outUrl.empty() && !outToken.empty();
catch (const json::exception &e)
std::cout << "JSON parse error: " << e.what() << std::endl;
return false;
size_t protocolEnd = url.find("://");
if (protocolEnd == std::string::npos)
outProtocol = "https";
protocolEnd = 0;
else
outProtocol = url.substr(0, protocolEnd);
protocolEnd += 3;
size_t pathStart = url.find('/', protocolEnd);
std::string hostPortStr;
if (pathStart == std::string::npos)
hostPortStr = url.substr(protocolEnd);
outPath = "/";
else
hostPortStr = url.substr(protocolEnd, pathStart - protocolEnd);
outPath = url.substr(pathStart);
outPort = (outProtocol == "https") ? 443 : 80;
size_t portSep = hostPortStr.find(':');
if (hostPortStr.front() == '[')
size_t ipv6End = hostPortStr.find(']');
if (ipv6End == std::string::npos)
return false;
outHost = hostPortStr.substr(1, ipv6End - 1);
if (ipv6End + 1 < hostPortStr.size() && hostPortStr[ipv6End + 1] == ':')
try
outPort = std::stoi(hostPortStr.substr(ipv6End + 2));
catch (...)
return false;
else if (portSep != std::string::npos)
outHost = hostPortStr.substr(0, portSep);
try
outPort = std::stoi(hostPortStr.substr(portSep + 1));
catch (...)
return false;
else
outHost = hostPortStr;
return !outHost.empty() && outPort > 0 && outPort < 65536;
Observed Error
res == nullptr -
Error message:
"Failed to read connection" -
Possible causes from logs:
Connection closed by server immediately after handshake
return contents:
Extracted nested URL: https://assets.ion.cesium.com/us-east-1/asset_depot/3644333/Mars/v2/tileset.json?v=2
Extracted temp access token: <TOKEN>
Requesting nested URL: https://assets.ion.cesium.com/us-east-1/asset_depot/3644333/Mars/v2/tileset.json?v=2
Error type: Failed to read connection
Possible reasons:
Time taken: 3945 ms
Questions
Does Cesium Ion have specific TLS or HTTP header requirements that differ from standard servers?
Are there known compatibility issues with cpp-httplib or certain OpenSSL configurations?
Has anyone successfully fetched Cesium Ion assets using C++ (not curl/Node.js/etc.)?
Any insights or working examples would be greatly appreciated!
Thanks in advance!
Environment: Windows 10, MSVC 2022, cpp-httplib v0.20.0, OpenSSL 1.1.1w
Feel free to copy and paste this directly into the Cesium Community Forum. It includes all necessary technical details while being concise and respectful of others’ time. Good luck!
