File Formats Supported by SingleTileImageryProvider
I’m working on an application that needs to be able to run disconnected and serve up a very small number of tiles. It looks like I should be able to do this using SingleTileImageryProvider layers for this, but I can’t find any information on what file formats are supported. I know png files work, but what other formats can be used? Do TIFF or geoTIFF work? Thank you.
–Dale
The Browser is the one that actually performs the imagery loading, so Cesium itself does not have any direct control over which formats are supported. GIF/PNG/JPG are going to be the most common ones, but here’s a fairly exhaustive list on Wikipedia: https://en.wikipedia.org/wiki/Comparison_of_web_browsers#Image_format_support
TIFF and geoTIFF are not supported by the major browsers (with Safari being an exception, but I haven’t tried it). Since Cesium can render Canvas elements as well, you can technically use third-party JavaScript loaders for various unsupported formats, like TIFF.
If you have a geoTIFF, normally the correct way to visualize it is to tile it up with a tool like MapTiler or gdal2tiles and then serve it up as a TMS resource. Of course this strategy is only possible if you have the imagery ahead of time.
Matthew,
Thank you. We would have the imagery ahead of time. I’m new at this, so I’ll have to look into how to use a TMS resource, but it sounds like we have a couple of options now.
–Dale
NASA has a bunch of public imagery layers that you can download and run through the gdal tools to have a pretty decent base layer. They don’t tend to get better than 250m so you’re not going to be able to have a really high resolution if you zoom close to the ground, but it’s a good starting point.
http://visibleearth.nasa.gov/view_cat.php?categoryID=1484.
I’m thinking about putting together a blog post about getting started with imagery for non-GIS professionals, but that is a long way off before it’s ready. It’s still percolating in my mind.
Mike,
Thanks for your input. If and when you get your blog post done, I’ll be interested in reading it.
–Dale
