Cypher
May 15, 2018, 10:23am
1
I'm trying to create an create a cesium app with opengee as provider.
I run into some issues like this one :
Failed to retrieve http://10.0.1.156/BayAreaHighways/dbRoot.v5?output=proto . Using defaults.
It seems there is the same problem in the gee sandcastle :
(I'm on Mac OS/Firefox, also try with Chrome)
Is this a probleme from opengee, the cesium library, or the code itself ?
Thanks for reporting this! We recently submitted a fix that makes the sandcastle example work when running locally, but it looks like it still fails to work on cesiumjs.org
I opened an issue here: https://github.com/AnalyticalGraphicsInc/cesium/issues/6589
I’m not sure what the issue is with the GEE server you’re using, but we will fix our example
Hannah
Ok, I will check my code.
Thank you !
