glTF model contains unsupported extension?
Hello,
Cesium ion currently does not support Draco-compressed glTF assets as the input. In order to upload your glTF to Cesium ion, just upload the original model directly, without applying Draco compression via the gltf-pipeline first.
But note that you can enable Draco compression for the output for 3D Models - and in fact, this is enabled by default:
We are considering to add support for Draco-compressed inputs, but note that Draco compression is lossy. When the input already had a high compression, then this might negatively affect the quality of the results. When the input is not compressed, then Cesium ion has all possibilities to optimize the data, and only apply the lossy compression of the output as the last step.
bye
Marco
