Use GroundPrimitive add Rectangle, The texture coordinates have an offset from the longitude and latitude coordinates.
Red line is texture coordinates 1/10, white line is longitude and latitude coordinates 1/10.
The offset of the rectangular area varies at different positions.
Hi @LiYang_Shi ,
Thanks for your post and welcome to the Cesium community.
Do you mind sharing sample code used to produce this example using our sandcastle tool sandcastle.cesium.com? This will make is easier for us to understand your example and investigate it as a possible problem.
Thanks and I hope with more information we can investigate further soon.
Luke
Thank you for your attention @Luke_McKinstry .
This is my sample code.
