I need help with the cesium water wave. How do I apply the moving effect of the water in cesium for unreal sample-9? Not now. I copied Editing Tileset Materials – Cesium but I can’t see the water flow. What should I do?
Hi @xkfahdnjem1010, welcome to the community!
The water animation only appears when you get pretty close to the water. Your screenshot may simply not be close enough.
Thank you. I’ve solved the problem and the other problem is that I’m using CesiumCartographicPolygon to draw a line of lectures, which is time consuming. Is there an automation technology that Cesium supports? (ex, technology that automatically polygons the line of lectures) Is there a similar technology without it?
Can you share your solution in case others have the same problem? Was my guess correct, or was it something else?
You can automate Cesium for Unreal using C++ or Unreal Blueprints.
Sorry, I don’t know what you mean by “line of lectures”.
