I have connected oculus quest 2 to the unity project and connected the google 3d tiles with cesium in the play mode I see the map but when I export it as apk and then put the headset I do not see anything
It’s hard to tell what’s going on without more details. Can you check the device log for errors? For example, it will log if it’s not able to find the necessary .dll.
Janine
I don’t see any errors do you want me to send you the project?
בתאריך יום ה׳, 1 ביוני 2023 ב-17:55 מאת Janine Liu via Cesium Community <notifications@cesium.discoursemail.com>:
| janine Cesium Team
June 1 |
.dll.Best,
JanineParticipants: Cesium Support (43)
Can you at least verify that the VR01_Denver scene works in Cesium for Unity Samples? It has a VR environment set up, but uses a different tileset. If it does work, then try replacing the Denver tileset with Google Photorealistic 3D Tiles. This would help narrow down the issue.
Janine
I dont know what is the vr01_denver, and this is the file of the unity project:
vr.rar![]()
בתאריך יום ה׳, 1 ביוני 2023 ב-18:35 מאת Janine Liu via Cesium Community <notifications@cesium.discoursemail.com>:
| janine Cesium Team
June 1 |
VR01_Denverscene works in Cesium for Unity Samples? It has a VR environment set up, but uses a different tileset. If it does work, then try replacing the Denver tileset with Google Photorealistic 3D Tiles. This would help narrow down the issue.Best,
This is what I mean by VR01_Denver (I mistyped, it really should be VR01_CesiumDenver).
Troubleshooting individual projects takes us a long time, and it would help if you could try the previous suggestion first.
i still didnt understand what is the vr01_cesiumdenver and how I use it
בתאריך יום ה׳, 1 ביוני 2023 ב-19:00 מאת Janine Liu via Cesium Community <notifications@cesium.discoursemail.com>:
| janine Cesium Team
June 1 |
GitHub - CesiumGS/cesium-unity-samples: Sample project for Cesium for Unity
Sample project for Cesium for Unity. Contribute to CesiumGS/cesium-unity-samples development by creating an account on GitHub.
can you please answer?
בתאריך יום ה׳, 1 ביוני 2023 ב-19:03 מאת מן סטאר <harelrubin123@gmail.com>:
Janine linked you to the Samples project, which includes a scene called VR01_CesiumDenver. Here’s the link again:
Here’s a direct link to the releases page, where you can download the Samples project:
There are some instructions on that page about what to do with it.
hi!
I did everything and it works!
but I want to ask, I added a script to take a place name and say the coordinates but I don’t understand how I need to put the output automatically in the cesium georeference
בתאריך יום ו׳, 2 ביוני 2023 ב-3:04 מאת Kevin Ring via Cesium Community <notifications@cesium.discoursemail.com>:
Sorry, I’m not sure what you mean by “to put the output automatically in the cesium georeference”. Can you explain in more detail?
Hey @Dallas_Steven,
Can you see if the same behavior happens when building the VR01_CesiumDenver scene in Cesium for Unity Samples? This will help us figure out where the problem might be happening. Thanks!
