Hi all!
I have created an application that shows buildings in 3D. It is working quite allright for the moment.
Basic setup is as follows:
Buildings get rendered using a tiling scheme, the tile gets “activated” with the use of the position of the camera
When the tile is activated, a WFS request is sent.
Buildings get rendered with the use of the JSON response
What I want to add is: when all buildings of the activated tile are rendered, the app automatically starts loading the eight neighbouring tiles (cardinal & diagonal).
I’m facing a problem here:
- I would like the eight additional request to be loaded one by one in some kind of loop. So: sent out a WFS request, render the buildings of this tile, sent out next request, …
How can I do this?
This is my code so far
for (var x = -1; x < 2; x++) {
for (var y = -1; y < 2; y++) {
// Code to make the request
var promise = Cesium.loadJson(request);
promise.then(function(geoJson) {
// Construction of buildings
So far, this code just makes the 8 requests and loads them simultaneously, but this is slowing things down…
Any help is appreciated!
Wout
