(AI Said This)
CesiumJS (Web-based)
If you are working in the browser, Cesium actively supports volumetric rendering for 3D Tiles, which allows you to visualize continuous grid data (like climate models, atmospheric data, and voxels). [1]
Voxel Rendering in 3D Tiles: CesiumJS features an OGC-compliant 3D Tiles extension specifically designed for spatial datasets represented as voxels, often utilizing custom shaders to control transparency, density, and color. [1, 2]
Custom WebGL Shaders: For atmospheric phenomena, many developers implement custom vertex and fragment shaders that map directly over the globe to simulate animated clouds and weather patterns. [1, 2]
Getting Started: You can explore the official Cesium Sandcastle (their interactive code editor), which contains pre-built galleries and demos specifically for Voxel Rendering and Voxels in 3D Tiles
Need help here
