How does Cesium's Entity material load the video of the monitoring class, and how to use the materia
How does Cesium's Entity material load the video of the monitoring class, and how to use the material to load the video data of the live stream in rtmp format?
Since the Video tag does not support live stream data in rtmp format, I introduced the videojs library to play rtmp live stream data. But this video is attached to the material of the entity, but it can't be played. After looking at the console, I found that videojs converted the Video tag into an Object tag. I don't know how to make the physical material a live video material. Do you know how to solve this problem? Or you have a better way to achieve this effect, please tell me, thank you!
This is a live video source in China. You may not be able to access this video source. If you want to test it, please replace the live video source address.
    <body>
        <video id="video" width=960 height=540 class="video-js vjs-default-skin" controls>
           <source src="rtmp://58.200.131.2:1935/livetv/hunantv">
        </video>
        <script>
            var player = videojs('video', {}, function(){
                this.play();
            var material = new Cesium.ImageMaterialProperty({
                image: document.getElementById('video');
            var redPolygon = viewer.entities.add({
                name : 'Red polygon on surface',
                polygon : {
                    hierarchy : Cesium.Cartesian3.fromDegreesArray([-115.0, 37.0,
        -115.0, 32.0,
        -107.0, 33.0,
        -102.0, 31.0,
        -102.0, 35.0]),
                    material : material
        </script>
    </body>
I need to play the surveillance video on the material of the entity, but the surveillance video is the live stream data of rtmp, I don't know how to load it onto the material of the entity.
Cesium1.51
Windows64
Google Chrome
See answer here: https://groups.google.com/d/msg/cesium-dev/vOzLJkJFew8/88MWH8-RFAAJ
