How to determine whether the load is complete in Unity? I need to do some things after the load is completed again
Hello Liqiang
A trick I use is enabling the logs selection stats and retrieve them in unity.
If I have no logs within a certain number of frames I assume the load is finished.
The long term solution would be to patch Cesium3DTilesetImpl.cpp
Here is a snapshot of the code I use
Application.logMessageReceived += (string condition, string stackTrace, LogType type) =>
if (!condition.Contains("[Cesium3DTilesetImpl.cpp:"))
return;
Regards
We have an issue for this, but haven’t implemented it yet.
In the meantime, @carlopiersanti’s suggestion is a good workaround.
