Hello @yangyingjun ,
It looks like you may be having the same issue as the user in this thread - Load TileMapService - #10 by agallegos
If so, the issue is likely caused by the tool used to generate this dataset. You may want to consider using Cesium ion to tile and host your data. You can find more information in the post linked above.
Thanks,
Alex
