How to reduce unexpected ripple on 3d model?
Hi all,
When I loaded 3d module with CesiumJS in Chrome, I met an unexpected ripple issue, like showed in the image below. Do you know the root cause, or how to fix it? Thanks in advance
@shmike
Welcome to the community! :grinning: :rocket:
Does the ripple effect only occur when viewing this 3D model in CesiumJS? If so, I suspect that you are noticing a Moiré pattern. Does this seem plausible to you? If so, I recommend that you check out out the following community forum thread:
https://community.cesium.com/t/moire-pattern-when-turning-on-soft-shadows/16011/3
@Bowen7 seems to be dealing with a similar issue. As I mentioned in his thread, I do not currently know of a quick fix to this issue. However, modifying the shadow and lighting settings may yield preliminary results.
-Sam
Thanks Sam for your reply.
As you said, my issue is similar with @Bowen7’s issue (#16011). It may be a common issue. Could you or @Bowen7 or others look into it?
