Shadow area appears at the rear part of 3Dtile
Could you tell me haw to remove it.
My cesium is v1.54.
The code is as follows:
It is very simple.
<!DOCTYPE html>
<html lang="en">
<head>
<!-- Use correct character set. -->
<meta charset="utf-8">
<!-- Tell IE to use the latest, best version. -->
<meta http-equiv="X-UA-Compatible" content="IE=edge">
<!-- Make the application on mobile take up the full browser screen and disable user scaling. -->
<meta name="viewport" content="width=device-width, initial-scale=1, maximum-scale=1, minimum-scale=1, user-scalable=no">
<title>TEST</title>
<script src="./Cesium/Cesium.js"></script>
<style>
@import url(./Cesium/Widgets/widgets.css);
html, body, #cesiumContainer {
width: 100%; height: 100%; margin: 0; padding: 0; overflow: hidden;
</style>
</head>
<body>
<div id="cesiumContainer"></div>
<script>
var tileset = viewer.scene.primitives.add(new Cesium.Cesium3DTileset({
url : './Tileset_022603/tileset.json',
viewer.zoomTo(tileset)
</script>
</body>
</html>
