**is it possible to remove the **CreditsDisplay ?
Technically yes. Write a piece of css and set display to none
ok … how to do it ?
I can’t find the place in the code that the code take the css from it.
or maybe to change the other icon and text
but still … all i did not work at all .
Just a reminder that removing the credits display may cause you to violate the Terms of Use for several of the datasets available by default in Cesium. It is perfectly okay to remove or hide the credit display if you plan on implementing your own version or only using data that does not require attribution; but assets such as Cesium World Terrain and Bing Imagery absolutely require credits to be shown.
