Remove cesium Logo
Hi
I Seriously praise the great work you guys are doing.
I want a plain screen in my application, please tell me how to remove the logo, search bar that come at top on the window.
https://github.com/AnalyticalGraphicsInc/cesium/issues/1245
In the above link, he doesn’t specify what to do exactly.
Looking forward for reply
Thanks in advance
Regards
Sid
Hi Sid,
You can disable most of the widgets in the constructor options for the Viewer.
For example, you can disable the geocoder (searchbar) with:
geocoder: false
There’s a thread on removing the logo here, but make sure you are not using imagery that requires attribution like Bing Maps.
Gabby
Hi Sid,
Thanks for the kind words on Cesium. Although you can remove the Cesium logo, we do discourage it as we think it is fair to credit Cesium as mentioned in the README.md:
GitHub - CesiumGS/cesium: An open-source JavaScript library for world-class 3D globes and maps 🌎
Thanks
Patrick
I’ve found the following solution helps and hides the logo.
css:
.cesium-viewer .cesium-widget-credits {
  display: none;
