qxiaok
1
omar
2
The docs have an example for UrlTemplateImageryProvider:
https://cesiumjs.org/Cesium/Build/Documentation/UrlTemplateImageryProvider.html?classFilter=UrlTemplateImageryProvider
For using TimeDynamicImagery, you might find it useful to look at this PR which added support for it in WMTS tiles:
https://github.com/AnalyticalGraphicsInc/cesium/pull/6348
If that doesn’t help, can you provide more info on what you’re trying to do?
qxiaok
3
how to add support for WMS-T Time parameter to UrlTemplateImageryProvider ?
在 2018年11月2日星期五 UTC+8上午3:01:19,Omar Shehata写道:
omar
4
I think you’d have to extend CesiumJS’s source to add support for that the same way this PR did:
https://github.com/AnalyticalGraphicsInc/cesium/pull/6348/files
What kind of application are you trying to build this for?
