imageryProvider/ ImageryLayer redraw tiles
Is there any functions such as redraw or refresh that when we change imageryProvider’s settings it redraws tiles on the globe? I searched the api for these objects but could not find any functions.
Can you describe your use case here? If you have tiles that update over time using a time dynamic imagery provider is probably the best solution: https://sandcastle.cesium.com/index.html?src=Web%20Map%20Tile%20Service%20with%20Time.html
Otherwise, you could remove and re-add the imagery provider.
In my case the tile’s style changes by a parameter in the url. so when user changes that parameter layer must be loaded again. in the leaflet there is a function named redraw which draws all the tiles of a layer from scratch. I was wondering if there is something similar in cesium as well.
What type of imagery provider are you using? If it’s something like the UrlTemplateImageryProvider, where the URL is readonly, I think recreating the provider would be the right way to go.
I am using a kind of customized imageryProvider based on this sourcecode
https://github.com/TerriaJS/terriajs/blob/master/lib/Map/MapboxVectorTileImageryProvider.js
I have two options. either change the url or change the stylefunction. I think they both will effect the newly loaded tiles but I think there must be a way to re render the already downloaded tiles as well otherwise there will be a miss match between the already loaded tiles and new tiles.
I am running into this issue too, in a very similar context. I am using an ImageryProvider to render vector tiles provided by a webgl context, and occasionally need to change the style to re-filter the dataset. I basically need a “refresh” method that requests the same tiles that are currently displayed and swaps them. I could reload the layer, potentially, but this does not seem like a very clean solution.
It looks like there is similar logic in the WebMapTileServiceImageryProvider, dealing with “time dynamic” layers, but I’m not sure how to wire that up in this case.
Following your lead on WebMapTileServiceImageryProvider I dug into the code and found that the base class of ImageryProviders has an internal method called _reload() that does just that - requests all the tiles that are displayed again. Obviously I don’t like using internal methods, but I’ve been using it and it seems to do what I needed it to do.
