We plan on changing/rendering imagery tiles in real time as the drone takes images in an offline setup. Our only concern is at the start we would like some initial imagery + dem(we are currently using .terrain files from srtm) for display. Any place from where , I could get and display imagery tiles or image would be appreciated
Could you tell me how you plan to do it? I’m creating a program to make fantasy maps with terrain, and the solution I found is to convert the pixel values to an array and pass it to the terrain provider, but I’d like to see more options, and if you don’t mind, could you reply?
@Haadi_M1 , is there a reason the built-in imagery providers (bing maps aerial etc.) and the Cesium World Terrain can’t be used?
No they can be use together. If I have a folder of images and I generate a dsm from these images and then convert the dsm into .terrain files which are stored in a folder, then I can serve terrains either from CesiumWorldTerrain or DSM Terrain.
