Hi, i have some problem with the new version of cesium for built in pipeline, when i install the package, i have this error ( by the way i don’t want to use thoses scripts)
any idea about how to solve that ?
These errors are complaining code that is used by the InputSystem package, which isn’t installed by default in new projects. But this code should only be activated if the package is present. I don’t know why it’s giving you these errors if you don’t have the package installed.
I just tried creating a new built-in render pipeline project, then installing the package, and I can’t replicate this error. What did you do that caused it to happen?
I just added cesium to my built in project, but i solved it by installing the inputsystem package.
