Unfortunately, Cesium doesn’t natively support rendering IFC files. is there any possibilities please reply to this topic.
Currently Cesium ion does not support directly loading the IFC format. However this an area that we would like to support. Are you able to provide more information about your workflow? (eg do you need to render the IFC file directly in the viewer, or are you able to upload it to Cesium ion first and then stream it to the viewer as 3d tiles)?
Hi Mark, thank you for your response. rendering the IFC file directly in the viewer is preferable. Alternatively, if uploading it to Cesium Ion and streaming it in the Cesium viewer is feasible, that would also work well for our purposes. our files are saved in aws s3 bucket.
Thank you
